I have been fighting with ball calls for months now. I have adjusted, cleaned, bent, sanded, and applied kicker strips. Still I have had too many calls.
For the month of February, I had 226 stops. 205 of them were ball calls. Totally unacceptable!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
I finally got fed up and decided to do some mods.
Phase 1. SBEs with mods.
Phase 2. Lift spring mod.
Phase 3. Zot Accelerator kits.
All but phase 3 are pictured here. Operation: Ball Return.
So far these mods have yeilded 3 ball calls in as many weeks. These were from string breakage on the SBE mod. I am going to redo those with aircraft cable soon to eliminate that problem.
Also , not pictured, a spring can be added to the SBE to apply even more pressure on the ball if necessary.
The SBE mod raises when the rake drops by a string or cable attached to the top of the cushion, then lowers onto the spinning ball to "kick" it into the lift when the rake goes back up. This mod not only helps balls to return more reliably, it also helps to reduce wear on the SBE as not all balls spin. The SBEs are adjusted to 2.5" from the lower rail on the lift rod.
The lift rod spring mod is a "porch swing spring" available at Lowes for $14.95 a pair. The original spring is cut. Part of it is inside the larger spring, and the other part is used as a flexible spacer.
The ZOT kit is awesome!! Not only does it prevent belt tracking problems, it increases the longevity of the accelerator parts thereby paying for itself.
Phases 1 & 2 are complete, and phase 3 almost is.
Any other ideas or comments welcome.
Disclamer: These mods are in no way meant to reduce PM. Cleaning , lubing, and checking adjustments are still VERY important for maximum performance.
