I think it would be nice if we could exchange some of the tips and tricks learned through experience, to make jobs easier and faster. This would be a good reference that goes beyond what is in the manual. From those who have "been there". For example, Roscoe's gearbox dissassembly procedures. If each mech could post a tip or trick each week, then we would have a great database for quick repairs.
My tip..Rakes.
This weekend our junior bowlers had their state tournament. I went to watch Sunday and noticed something that really gets on my nerves. The center had A-2's with links. Their rake boards were all over the place!! Some were 5 " above the lane, and some actually hit the lane.
I use the method prescribed by Masternut, and all of my rakes are 2" - 2.5" above the lane at 90 degrees. Very seldom do we have a deadwood call due to the rake. I also adjust the sweep links to the spec in the manual to keep the rake from slamming against the stops so hard.
Just remember, the customer sees 2 adjustments on the machines. The rakes, and the pin spotting.
Masternut's rake balancing adjustment:
<font size="2" face="Verdana, Arial">
The rake is then adjusted as low as you want it. I usually go with 3/8", but 1/4" is now possible.
All other rake adjustments are as stated by the maunal. I just substitute this method in place of the rake cam adjustment.
Lets hear some other ideas!!!
My tip..Rakes.
The sweep pattern is different sweeping forward than sweeping back...
Take the first measurment between the 2,3_4,5,6 pin spots as the rake is going back(towards Pit).
Take second measurment at 1" behind head pin as rake is comming forward.
These are the two lowest points in the cycle.You want to balance the cam until these measurment are the same(Within an 1/8).
If measurment 1 is lower than measurment 2 then you need to retard rake cam ,if measurment 1 is higher than measurment 2 then you need to advance rake cam.
