2 amp fuse,Jap a-2s
  • 2 amp fuse,Jap a-2s
    Where can i get the 2 amp fuses for my Japs?Radio Shack,Sears,local electrical have nothing.And why do Japs need 2 amps and Americans 1 amps??
    Oh i can find the 2 amps but not same size!,these 'lil buggers are fairly small compared to the usual sizes.
    Can i change the fuse holder to a larger style or ?
    Brunswick etc do not have the original 2 amp jobbers.Also,for the 5 amp fuse should it be of a slow blo nature or fast acting?I would assume fast acting.
    Thanks for replying!
    These fuses look like the older car fuse styles.
    Re: 2 amp fuse,Jap a-2s
    Any fast acting 2 or 5 amp fuse will do the job. If you want to change the fuse holder so you can use a common style fuse...go for it. You will find it cheaper in the long run to do so. The important part of a fuse is the filament and when that filament will melt. How long or wide the glass is will make no difference in how the fuse will work. As far as why the Japanese version uses larger fuses, the transformer is rated at a higher wattage rating. My belief is it was being prepared for possible future additions like auto-scoring and other as of yet unknowns...like quick drop rakes from Zot. The Japanese transformer is better equipped to handle such add-ons. If you have to replace a Japanese transformer and you end up using an American replacement...be sure you change the value of your fuses to match the new transformer. I've seen a few guys burn up new transformers in Japanese machines and wonder why...they always comment that it's a new transformer...why did it die. They didn't change the fuses to match the maximum current rating of the new transformer. Good luck...
