WEAK 120 VAC CONTACTOR
  • WEAK 120 VAC CONTACTOR
    Hello there to everyone, it’s been awhile since I gotten to check the message boards I have been busy remolding a Sports Bar in our center.
    I have a question for everyone, I recently purchased several 120vac motor contactors (12-900201-000) from Brunswick and I think I got a batch of bad ones and I was wondering if any of you have been having trouble with them lately. The brand names on these are Deltrol Controls. The Problem that I am having is that after about 2 or 3 weeks they seem to get weak and will open while the machine is on. Just 3 weeks ago I installed one of these contactors and it lasted 3weeks to the day and then the same old thing.
    Anyway I just was wondering if anyone else has had a problem like this out of these contactors.
    Thanks
    Doug
    Re: WEAK 120 VAC CONTACTOR
    check motor start relay
      Hey guys sorry I made an error on that part number it is 12-862111-000. It seems as if though that the coil winding are not holding up as good as the old Federal Pasific and Bradley Contactor. This is not a new thing to our center or other centers in our area that use this contactor and I was just wondering if anyone else has had this problem out in the big world.
      Doug,
      Forget bowling machines a becomeing sports bar builders.
      Ps My pinchasser mistyped the part number before
        Here are a few things to check.
        First check your deck jam microswitch to make sure it is mounted tight and the cable tube is mounted tight so that the switch does not flicker when the deck shifts at 180.
        If you have a good contactor you could ohm it out and then ohm out a new contactor and check the readings.
          Are you stating that they open and stay open or do they just flicker...like at 180 degrees?
            FYI on this multi-forum post:
            From General Discussion
              There is nothing wrong with anything on our machines we are just getting bad coils. The machine will be running and the coil will open you can take a meter and watch the coil and when the coil cools it will close and the machine will restart.
              Belive it or not we had another coil this week go bad.
              We are going to buy up stock in the daltro coil company cause there business has got to be booming!
              Doug [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
                Doug:
                What is the voltage reading at the coil under load? Suggest a digital meter for this application.
                Roscoe.
                rfm
                  Roscoe
                  The voltage is 120 at the coil. on the deltrol contactor is not as good as the old ones.
                  we never had this problem untill we started changing from guardian and federal pacific.
                  Doug
                    I have been replacing old contactors (Federal Pacific) for quite a while now and I have yet to have one fail. How long does it take for one to "open" and then to cool down and close again?
                      Steve
                      The new deltrol contactor when the coil opens it can take from 1 to 5 min. When it cools the machine will restart I did not run in to this problem untill latelty . I have worked on a-1 and a-2 since 1974.
                      [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] Doug
                        Do the new contactors have a built in thermal overload switch on the activation coil? Any contactors I've worked with just have a continuous duty coil for activation that is not affected by the switched load. Do you have this problem on more than one machine and have you checked the contacts and connections on the motor start relay? I have only changed a couple of contactors in 25 years but I've seen a lot of problems that caused one to malfunction. Every thing from jam switches to bad solder joints to cracked fuse links on the 3.2 amp fuse. If the activation coil is black and crispy I'll believe the contactor is bad otherwise I'd keep looking elsewhere.
                          Just another quick thought, if you replaced with the kit which also has the motor overload relay did you match the heater coil to the pinsetter motor?
