Rake shaft walloring out the bolt holes
  • Rake shaft walloring out the bolt holes
    Guys, Ive goot a rake shaft thats making its own size holes in the frame. Had a zot shaft in but was rubbing on the deck. "head mechanic" didnt like it rubbing so I replaced it, he didnt know how, to replace that is. Ive got the wooorst GM you could ever have! Hires people who are not even ready for the job, instead of looking inside! But anyway what size steel bearings should I use to tighten up this rake shaft?
    Thank you guys I know you will give me good Ideas,
    William
    Re: Rake shaft walloring out the bolt holes
    Hey wmj don't worry I will send you over one of my reinforced specially welded and aligned English ones - no problem, have a nice day today.
