We have ball accelerators and on one pair the balls hit the lift hard and make a clunking sound.
I replaced the leather and plate but then the leather was marking balls,i changed the lower tire(i use the black v-shaped),added some spare carpet to the top of the leather pad,tried shimming the plate assy up etc.It still wants to do that hard clunking.
I can quiet it down some with the added carpet idea i did but then when i use a 6lb ball it sticks in front of the lower tire at times.
I've checked the other lanes and comparing heights,widths etc it seems good.
OH-i did change on lower c-track,it was all cracked but the noise was there before that.
It like if you roll the ball twords the lift,there is a slight dip in the plate area and that seems to be the trouble spot so that's why i tried filling the spot up with carpet but...it's slightly better but not a long term fix.ANY other ideas?Slow ball speed down from the accelerator??
