4:1 brass gear question
  • 4:1 brass gear question
    I recently relaced a bad unit and was rebuilding old one anyways long story short.I got distracted after pulling brass gear off shaft, which way does the gear face?Does the high edge facethe bearings or the low side go there?I have no spare to look at and its a bruns gear no directions printed on it like quality brand has...Thanks guys
    Re: 4:1 brass gear question
    Pinhead:
    High end goes to spur gear, short end to bearing.
    Roscoe.
    rfm
      Thanks for the correct info saved me alot of time n trouble...
