Just a question
  • Just a question
    This may seem like a dumb question, but it's one I can't figure out....
    Why does the extended cycle cam have a low dwell at 180? What purpose does it serve to lift the lever there?
    I think I know the answer.. (so the 180 link can fall out of it's slot easier)
    Is this correct?
    Re: Just a question
    Correct on that, if the 180 link was not allowed to move in the locked position on the actuator link the machine wouldnt come out of the 180. Thus having the reset lever fall into the low dwell allows the link to move into the slot provided to have the machine set pins.. Basically, you answered your own question. Just my .02 worth.
    msbowl [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
