quality rake arm
  • quality rake arm
    I am currently installing a quality
    rake on a jetback and where the rake hook
    attaches its too wide Do I need other parts,
    shim it, or is it the wrong one Part No.12-2585
    I may be an [beep] but then again i'm honest
    Re: quality rake arm
    Hey guys talked to quality they said
    it was a defect and a few slipped through
    Just my luck
      Cab, where I'm at we're currently converting all of our rake assemblys to quality and I haven't had a problem, stay with them there much easier to fix if they break.
      soon to be great [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
        I'm not saying anything bad I agree they do
        make life easier my problem was the two plates
        that hold the rake hook were welded 1/2 inch
        too far apart
