Spring Tube & 4-1 crank
  • Spring Tube & 4-1 crank
    The crank on the 4-1 hits the rear most part of the springtube when cycling on 1st ball or when it's on 2nd ball deck held up on deck hook.,during full deck stroke nothing hits.
    I used a small level and the mount for the rear of the springtube is straight but the crank part of the 4-1 hits it,the part that hits it is the 2"(or so)where the crank rod slides onto and is retained by the retaining ring.
    It's more like a slap on the side of the tube not a major hit unless i let it go and a groove get's worn in it but i'll fix it by then i hope. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
    Never seen this before anywhere,front of the springtube is attached solid and in great shape.
    Deck shaft shift on me??? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    Swapping tubes is no problem but since the mounts are good it's somewhere else??
    Goofy is'nt it!
    Re: Spring Tube & 4-1 crank
    Gearhead.
    You have to pry the mounting bracket that is part of the deck lift shaft slightly to achieve the needed clearance. Not terribly uncommon.
    Roscoe.
    rfm
      Thanks Roscoe,i'll try that.
      In doing years of this work i never ran across that before..always learning!
        I had a similar situation here last week. I found that the retainer ring that secures the rake crank rod had popped off. It looked fine when sitting there, but when the machine cycled, it would pop to the outside and strike the spring tube. Just a thought.
        41 years and still learning....
        lanedoctor@hotmail.com
          Roscoe had it,i had to pry it over a bit....much better now,thanks Roscoe!!
          I thought about doing that at first but it all seemed level and all so i had to ask for ideas.
          Just had to say Thanks!
          Sorry for a late post.
