Has anyone else had some bad time delay gears?Reason i ask is that last night i had to change out a new one for a good used one to get it to work.,it's the 2nd time i've done this here.
The post was binding on the oilites i assume since it would not turn,put in used and it's okay.
It looks different on the underside than the used one i put in,the used on has a groove that the index bellcrank bearing rides on and the new one has just a flat surface.
The new one was properly lubed and yes the torsion latch is fine.The underside has a short small metal block and a large metal ramp like block/stop.that's the one(the larger one)that's not like the ones on the used unit.ODD yes.Like it was mis-machined but of course i didn't notice it until it was too late,ran fine last night even though i saw it turn slow/sluggish and once leagues started it would not function so move bowlers over then get to it later on.
Runs great now with used one.
I did have one that the teeth on the time delay gear did not fit into the friction disc teeth.
