Pinsetter lights
  • Pinsetter lights
    Which A/A2 pinsetter deck lights work best with the frameworx scoring system? I replaced a deck light with another bulb today and it made the pins look alot whiter and brighter. Most of the pinsetters have chroma 50 bulbs in them. I will see if it effects the scorers during cosmic tonight.
    Sharpie
    Re: Pinsetter lights
    Sharpie,
    We use F40SP65 lamps. They provide excellent light making the pins appear cleaner and brigther. It also provides light along the back row of pins reducing scoring issues with Frameworx camera's.
      You can get the F40SP65 light at granigers #2F063.
      Lowes has also started carring this color bulb.
      Peanut
      Peanut
        Thank you for the responses. I will be getting some of them when I order a case of bulbs Monday. The bulb I put in seemed to work fine.
        Sharpie
