Short Link
  • Short Link
    I was wondering if any knows where I might find a few adjustable short links?
    Thanks
    Wags [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
    Wags
    Re: Short Link
    I don't think there are any on the market now, but last time I needed one, my vise was happy to help out, just bend it slowly and be sure to keep it straight:
    Kevin
      Re: Short Link
      Hi Wags,
      I built one not too long ago. I cut a section out of the middle and bought a turnbuckle to replace it with. I ran both ends of the link through a die and the screwed them together with the turnbuckle using jam nuts to secure it. It worked very well, the key would be to find a reversed thread die so you could adjust the short link on machine without having to pull one side off like I had too. It can be done fairly easily.
      Jerrid
        Re: Short Link
        I wish I could find a set of reverse taps and dies. That would be really useful. Anyone know where they could be found?
          Re: Short Link
          You may want to try Ace Hardware. If they cannot order reverse taps and dies then the other option is a machine shop. Check Ace first and see what they say.
          msbowl [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
