Time Delay
  • Time Delay
    We have a problem with the time delay on 2 pairs of lanes. We have A-2 conversions with AMF Accuscores. The time delay is reversed on both lanes (both pairs). The cycle starts immediately on first ball and has the delay on the second ball. I know the problem is in the ball detector or the ball detector relay because when the problems occured, it was when someone changed the ball detector or the relay. Let me know what you think, and I'll be sure to get back to you. By the way the switches on the ball detector are in the correct position and the relays have also been replaced.
    Re: Time Delay
    I would go to the root of the problem. If the time delay sequence is reversed, I would compare the wires one for one with a pair that is correct. Sounds like there are wires reversed on the K-1 relay base. Very touchy area if not secured properly. Just out of curiousity, do you have Bowl-tronic's?
    Mark
    (919) 757-1789
