Okay,i have several pit boards that need to be changed(worn carpets)but....some boards do not fit into other frames,they are too short or too big!I have the bolt in frames and quality quick release frames.Example...lane 12,installed new upper frame(quality)and i went to install a NEW Brunswick complete pit board but where the clamps are they are about 1/2 inch short from completely clamping the frame down,they grab the board enough to hold it in place.
Now if i try to take that same board and put it into lane 4 it in no way fits!!Lane 4 has an older style quick relaese frame.
I thought a pit frame was a frame but not here,sizes vary so to do what i need(about 7 carpet jobs)i guess i'll have to pull a board,strip it,re-carpet it and put it back into the same lane.WHY are boards not all the same,here at least?The last place i was at i could put the pit board from say lane 8 into lane 36 w/o any trouble.
This center is about 20 years old and ALOT of the pit carpets are probably that old too!I have tried removing the rubber pads on the underside of the boards but still it does'nt help to get it to fit into some frames.It's like each lane has it's own size of board it will accept.Can anyone offer advice as to why the boards are not interchangeable here???The boards here are mainly fiberglass with some composite sort of boards.
