spinning ball eliminator
  • spinning ball eliminator
    Has anyone tried the spinning ball eliminator kit that slows the ball wheel way down and has a couple of metal pieces welded or rivit to the ball wheel?With this kit the rod covers are removed too.It seems to work real well but it is rather expensive,I believe it is 550.00 per kit.
    Re: spinning ball eliminator
    are you reffering to the "ballchaser"? if so it went way of the dinosaurs.
    alex
    Cloth: ShamWow!
    Machine: Johnny 5
      It is still out there but is called the ball call eliminator. Yes it is very expensive. We don't have that many ball calls to afford to spend that much. They have a web site of the same name as above.
        Yes, it is the "ball call eliminator"I was talking about.
          I couldn't see that coming back as ball calls are around 1-2 a night.
          Drill
          Drill
          David Bolt
          Champaign, IL
          USBC Silver Coach
          IBPSIA BOD
          IBPSIA Advanced
          Technical Certified
          Pro Shops
            If you want to buy one and send it to me, I'll try it out for you free of charge!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
