Short turret belts
  • Short turret belts
    Has anybody other than me had performance problems with new short turret belts? I just ordered some new (Brunswick) and installed one Thurs. tonight(Fri.) I had to loosen the long turret drive spring with a 5" eye bolt to stop multiple indexes. The new belt seems to have way too much grip on the clutch pulley. The new belts look different than the older ones on my machines in that they are rubber on the sides rather than fabric. Or am I the only one having problems? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    Re: Short turret belts
    I have one machine with that eye bolt set up too,NO other adjustment worked so i had to go with that.
    Ran into another problem,wanted to change short belt on a turret and the new one is too short whereas the time delay hits the turret cam,yes it was fully in the slides and they are fine too.Belt # 12-150113 is what's on it (48" old belt)and it has the same number BUT the new one same number and size is too short.I remember having to use the longer belt 27-8620 (49.5") to get things working at another place i was at,after that, all ran super.
    Why is it that the new belts seem bigger(fatter)and shorter?I'm going to try napa or other auto parts stores for belts.
      Sherlock,
      I to have discovered that the new brunswick short turret belts have alot of grip and pressure. I ended up using the longer belt to make them work smoother. It's funny when you go to replace a worn part thats going to give you trouble, But yet you end up with more trouble anyways. It's all about money now and days not quality. I have thought about trying Murreys short turret belts!!
      Mike
