Retro field kit avaliabilty
  • Retro field kit avaliabilty
    57-860252-000 retro field kit for the new pin solenoid. We are experincing dificulty trying to purchase this pc board. Ace Mitchel informed us that Brunswick is no longer making this board.
    Is there any ideas where this part can be purchased.
    Doug
    Re: Retro field kit avaliabilty
    Doug
    The first thing I would do is to call Brunswick and ask them what they are replacing them with.
    If I have any laying around I'll send to you.
    Also check other centers that may have had B scoring and changed over to AMF. Most of your AMF centers have done this.
    John B
    just fix it
      Belive it or not after doing some checking Brunswick has put us out on a limb and lost there distibuter for this part and a Brunswick Represinitive said that at this time they do not have a supplier for this board and at this time 150 boards are on back order to Brunswick.
      Brunswick needs to take a serious look at this situation.
      Doug [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
        Well one thing to be thankful for you are not down. Just first ball foul and third ball 10th frame not working leads to a couple of complaints and use of the reset button.
        What happened to me a few years back was the motors for the 86 scanner were dicontinued for a while. That made it very hard to eliminate down time. I had to get good at rebuilding motors from scratch. Brunswick got another vender a year later and started resupplying them again.
        John B
        just fix it
          On the West Coast we rely on ISS Pro-score, or Don Madden Electric. He has A LOT of stuff. As far as scoring stuff. Old and current. I'll bet he can help you. 909-684-2695.
            I cant belive that Brunswick has left me hanging again, they havent even read our post are the so busy that they dont even look at this site anymore. If not I hope they are getting a new distributer at least. Problems like this is a large determining factor in the type of scoring systems our company will purchase in the future.
            Doug [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
              I have a couple on back order. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] Till they get here bowlers will just have to push the reset in the tenth frame.
              Sharpie
                Check to see if you can get relays to replace the bad ones. This is the part that goes bad. Once I ordered new boards and Bruns. sent me relays instead. They have 5 solder joints but can be repaired.
                John B
                just fix it
                  As a Mechanic of 29 years I think That Brunswick is the one that needs to push their reset button and rerack their staff.
                  Doug
                  We can't fix what we dont have.
                    <font size="2" face="Verdana, Arial">That is one really Funny statement , [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    Surely , there must be an aftermarket source that can supply &amp; / or repair this equipment out there somewhere ? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
                    Cybernetics here in Australia comes to mind , But I cannot find there Web Site [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                      A relay that will work on the board is an Aromat JS-1 6VDC relay. You can get them from newark electronics fairly cheap. You will have to modify the board by drilling a couple of extra holes and also adding some jumper wires to make the connections. I have not been able to find a direct replacement for the relays as of yet. If anyone knows of a place where they can be found, please let us know.
                      BTW...This relay is the same one used on the brunswick auto triggering boards so you can save some money on getting them repaired. I have one to replace today as a matter of fact.
                        Adam, Thanks for your information this is just what we were looking for but, could you email me a diagram of the modifications you are talking about.
                        Also, is the relay your talking about a 6 vdc contact located on the 12-862584-400 module. if it is we have dist. to purchase the relay from.
                        doug [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
                          Yes, that is the same relay. I will be sending you an email ASAP.
                            First of all Thanks, Adam D. for the email on how to fix my relay problem. This will be a big help to us while Brunswick gets there ducks in a row.
                            And also I would like to thank the whole bowltech comunity for being here to help other mechanics in need.
                            Doug [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
                              Also , try ALLIED ELECTRONICS for the replacement relay.
                              When the "B" manufactured these and many other boards they used a 6 volt coil relay and I had problems with them chattering because the logic voltage that signals this board is 5 volt, with the length of the cable the voltage drop was high enough that the the relay would not consistently pull correctly, burning the contacts.
                              After a bunch of burn outs I finally bought high amp rated contact relays(almost same package) with socket and hard wired the socket terminals to the board, then hot glued the relay to the inside of the box. A 5 volt 12 amp socketed relay, easy to change out, more current handling and no "B" over priced parts. We had AS_80's that were 16 years old and never lost another one(relay) again. If you have the "B" electronic triggering boards do the same to them for the cycle solenoid relay.
                              BEER: It's not just for breakfast anymore.
