Easier way to replace a jogger link?
  • Easier way to replace a jogger link?
    Is there an easier way to replace a jogger link without having to pull the whole vibrator shaft? Then once you get it off, how do you get it back on with no room for a hammer?
    I have a bearing starting to go on one of these. I have tried using a pry bar with no success. The only way I have been able to remove one of these in the past is to remove the whole vibrator shaft and use a bearing puller then beat it back on with a hammer.
    Any ideas or tricks, or should I just continue pulling shafts?
    Re: Easier way to replace a jogger link?
    Adam:
    I keep a shaft, with everything built, on the wall. 8 Bolts, a LOT of cussin, and you're done. Just no room to work in there, so minimize the time you spend in there, and rebuild the other one where there's room to work. Saves time and aggravation in the long run:
    kevin
      Just call me stupid but when I work on a “B” pit I pull the entire pit and install a rebuilt one in its place. Take it out in two pieces. It’s a little heavy but makes the inspection and rebuild much easier.
      JMO
      Please buy MADE IN USA!
        That's what I was afraid of..
        Fortunatly I have an impact wrench so it makes the job a little easier.
        Ed, I wish I had a spare. That would be nice.
        Owners were talking about buying 1 or 2 whole machines for parts. I wish they would. 1 or 2 thousand dollars for about 20 or more thousand in parts. Anybody know of a place where I can find some 60,000 series A's? Or better yet converted A's? That way the parts would be about the same as what I have.
          We have 4 complete spare machines minus the pit cushions and curtains and I think they are close to the 60,000 series.. I'll check when I go to work monday and let you know.....
          Charles
            Adam - I suppose I am lucky as I have 2 complete pit frames for emergencies, I can usually change one in 30 - 40 minutes (with help) and I think this is definitely the best way, you can then service the broken pit frame much easier in the work area. You also usually find a few aprts like X pins &amp; bolts when you take a frame out, maybe even the odd Allen key or spanner [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] Tried the other way (working in the pit) - not recommended for 60yr olds!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] I also keep a spare cushion assembly for the same reason.
            Good luck whichever way you do it.
              Best to keep a spare unit ready to go.It's not that bad changing one out,about 1/2 hour for me tops.,longer if i change ALL the rubber mounts so i know it's all done!
              Just don't put the drive pulley on wrong like i did a long time ago,the pit runs funky!Very funny to watch run but not fun to re-do. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
              Had some mild success removing the needle bearings with a pulley remover and large socket, yet, all in all,easier to yank the thing out. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                I have to agree [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] about pulling the whole thing. Unfortunately, brunswick never gave it any thought about doing a repair inside an area slightly larger then 4ft and then God never meant for us to be put positions totally unknown to man. Especially if you are a tall person. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] . It is always best to pull the assembly and get it done right the first time. Second times are not fun at all.
                msbowl [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                  It's all done now. I had to pull the shaft anyway as the bearing had worn into it. Hate it when that happens. Kind of funny though. The shaft bearing mounts were frozen to the pit frame. Had to use an old vibrator shaft to pry the old vibrator shaft out. Go figure! [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                    Just a thought...do you lubricate the vibrator shaft and jogger arm bearings as you should? I went and did all 60 at one place and all 12 at another place. I do them about once a year...even though Brunswick recomends greasing them 4 times a year. =)
                    ß A
                      Originally posted by badams900:
                      Just a thought...do you lubricate the vibrator shaft and jogger arm bearings as you should?....
                      <font size="2" face="Verdana, Arial">Yes, I do that. However I have not found a way to refill the ball bearing on the jogger link. Kind of hard to get to with a needle. I do grease the main bearings and the needle bearings though.
                        To refill the large jogger bearings i just carefully pull off the seal,repack it and put seal back on,i use my spring hook tool.
                          This is what I use to grease the needle bearings.
                          [img]http://pic4.****************/VOL50/488633/748848/8771311.jpg[/img]
                          I made this and it works great. I have them on most of my machines now.
                            NICE IDEA ADAM, THATS GOT TO BE A TIME SAVER...
                            Mike
