Gearbox Drive Disc Clutch Face
  • Gearbox Drive Disc Clutch Face
    Can anyone tell me the diffrence between the earlier and later clutch face kits? (12-862864-000 &12-862864-005)
    Also are they interchangeable?
    PC
    Re: Gearbox Drive Disc Clutch Face
    The earlier facing kits were for the first gearboxes that had a brake disc as the worm shaft bearing retainer.
    The kit has two sets of facings one for each side of the drive disc. the rivots are also longer to accomidate both facings.
    As far as the facings they are the same.just longer rivots.you need the shorter rivots for the one facing kits
    Peanut
    Peanut
