cam follower bearings?
  • cam follower bearings?
    here's a stupid question. does anyone out there have a secret to getting the cam follower bearings off or on? for example the geneva rollers bearings and the spider release bearing? the bearings have a space for a slotted screwdriver then they put that pin thing right in the middle of the slot so it is impossible to tighten or remove them. i have a few that are loose and i feel they are causing my blackout problems but i can't seem to get them tightened. does anyone know of a manufacturer that allows you to use a hex key to install them with. just curious.
    thanks
    alex
    Cloth: ShamWow!
    Machine: Johnny 5
    Re: cam follower bearings?
    I use one of my spring hook tools to pick those TINY plugs out then i can install the geneva rollers with no problem.I think that TINY piece is a dust plug of sorts and or a spot to where you can put a zerk grease fitting.
    I have a set of hook tools that have 5 various small/thin bent ends,got them from Ace hardware.,let me tell ya...those tools have saved me from pulling a detector when a spring breaks,a little working and i get some detector springs in too!!They come in handy for other stuff too.
    After you get that TINY part out,use a thin head screwdriver to hold it in and tighten it down.
      I"ve had luck with the spider bearing by using a pair of channel locks,,(gooseneck Pliers)clamping onto it at an angle agianst the tureet ring alot of times you can lock it from turning and get the nut off.Other fast way is get a very sharp chizel and heavy hammer and litterally shear it off above the nut chances are the threads are stripped off anyways from being loose.And yes loose spider stud bearings will cause blackouts and deckjams.
        Grind a notch dead center in a large flat blade screw driver. Your dust cap stays in place and you can still get grippage.
