Having troubles with the full deck-moving deck interlock. The lever on the interlock cross shaft keeps jumping behind the hub. As starters it caused the turret frame to snap on the 7 pin side, got that fixed, next we put in a new interlock cross shaft, new lever, did the adjustments, still same thing lever jumps behind the hub. [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] We have also done the moving deck-scissor latch adjustment, did not help. Has anyone run across this before? We can not seem to see why the lever goes behind the hub. Machine is running now with 19 pins but we have just enough tension on the lever to let the turret probe clear. Any help on this would be more then helpful.
Thanks,
J.D. [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
Thanks,
