Bent rake arm's.
  • Bent rake arm's.
    ok. i have a bent rake arm. how can i Un bend it
    or should we just replace it ?
    its bent just under/around the cannon and rake stop points.
    ~~(__)B>
    Re: Bent rake arm's.
    If the arm hasn't cracked or been otherwise damaged, you could try heating it with the oxy and straighten it up. I'd be inclined to brace it with some angle iron as well once its straight.
    Duct Tape is just like the Force. It has a light side, a dark side and holds the Universe together.
      Thanks, thats what i was planning to do.
      just didnt want to weaken that spot on the rake arm..
      ~~(__)8>
      ~~(__)B>
