moving deck
  • moving deck
    anyone have the part # for a washer that goes on the lower deck cable sheild i had pinfinder that one piece acts as a washer got rid of all that junk thanks jb
    Re: moving deck
    12-200065-002
    Washer
    Item D-38 on page 52 in green parts book.
    Current price...$7.70...wow...I think I would leave the old pinfinder bracket on or cut the bracket so it looks like a washer...
      Re: moving deck
      7.70 dallors for that! it should be illegal might have to cut the bracket alot cheeper thanks
        Re: moving deck
        I just keep the bracket. It's much less painful than being robbed to get the washer.
        Idiocracy
          Re: moving deck
          While we're on the subject, I'd just toss the bracket, and buy a regular flat washer and bolt to hold the stuff on ... if you strip the head out of the allen, you'll find out what it's like to have sex with your pants up when you get the bill for that custom allen bolt:
          Kevin
            Re: moving deck
            When I worked on A2s, I cut a flat on those washers so that I could grip them with a large wrench. Then i would turn the washer at the same time I turned the bolt. Problem solved.
              Re: moving deck
              We used a regular hex bolt and washer on our last center.
              I made a mistake at our 52 lane center years ago and called and orderd 52 "washers" without looking at the price...I mean its just a washer right! WOW when the invoice came in.At that time they were 5.65 a piece. a lesson was learned.
              Peanut
