This one's gonna sound SO NEWBIE ... but it's simply been so long since I've had to build one:
When putting the main bearings on the shaft, do they want to be just far enough on that the snap ring catches ... or is there a magic dimension ???
Got spoiled by the quality shafts with the roll pin holes, just beat the bearing flush with the roll pin, and the spacing was good to go ... Now I just don't remember:
From inside bearing to inside bearing is 51 3/8, I don't know if this is what your looking for but give a call if you need anything else. You still have my number I think.
Drill
Drill
David Bolt
Champaign, IL
USBC Silver Coach
IBPSIA BOD
IBPSIA Advanced
Technical Certified
Pro Shops
Thanx Drill, that's exactly what I was looking for. I haven't personally had to build one in about 8 years, and when you're in the pit ain't the time to find out the spacing's off:
