Time Delay
  • Time Delay
    Can someone please help me.
    I changed the time delay module and when i went to turn the power back on only the ball booster came on nothing else. I traced all the wires about 4 or 5 times and i cant find the problem.
    I tested the contacter and it is fine all the fuses are good. Im sure its something stupid.
    Thanks Mike
    Ken Forst "The meek may inherit the earth but the truly demented will still rule it"
    Re: Time Delay
    Switch that TD module with one in a working lane and see if the problem moves, all so do you have regular TD modules or Brunswick auto trigger modules
    Peanut
      Re: Time Delay
      Problem solved the spring that moves the leafs up and down on the motor start relay got knocked off.
      dont i feel stupid. put spring back on and it works fine
      Good bye from
      Paradise
      Mike
        Re: Time Delay
        Don't feel stupid man. Just be happy that is was something simple.
        Wish I was feeling the rays of paradise.LOL [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        Ta Ta for now,
        Joey
