Minikit A's with shotgun/quick drop rake.
Rake board got stuck behind lane deck on 10-pin side during league. They pried it out. Now it looks like the rake arm repair (pipe inserted into rake arm, bolted through) near the shock is not straight. And the rake sweep is awful, lots of deadwood, and the 10-pin side is a little further towards the back of machine than the 7-pin side.
While sitting on the machine waiting for the next deadwood, saw the deck hook fall off its post during the 2nd ball cycle. Hook was worn, we changed it. Wondering if the deck had fallen onto rake once and started this mess. Got through next day by adjusting thin rods on 7 and 10 pin side, compromise between not rubbing the deck too much and not leaving too much deadwood. But one side of rake is higher than the other.
Question 1:
Looking at the previous posts, do we need to go through all the adjustments, and in a certain order? Or can we just do the rake height adjustment (Masternut method). Already adusted rake cam once to fit in low of dwell at 180. It was out.
Question 2:
We'll probably order a new rake shaft/arms assy for the machine. Do any of you have any preference? We've heard bad things about Brunswick's 3 piece design, particularly with the slotted key. We've got one Zot 3 piece installed for a long time, but the rake arms are thicker and have a tendency to rub against machine deck if not adjusted right. The Quality 3 piece comes apart at the arms, so that maybe easier to replace just one arm.
thanks
Question 1:
Question 2:
thanks
