Have a question about the deck spring. I am rebuilding a deck and was wondering how many turns to put on the deck spring. When I took it apart it turned one full turn. Is that enough or should it have more? Thanks for any help.
If you put more turns than one...you will cause undo stress to be applied to the moving deck/scissor cam. This in turn can cause you to loose the key/keyway on the 1:1. I have worked on a few machines that have lost the 1:1 and found the deck too tight from 2 turns on the shaft. I guess some mechanic somewhere sometime thought more was better...not always... [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
