Scoring Problem
  • Scoring Problem
    Ok I am having a scoring problem. My problem is this, When a ball is thrown down ln's 1 or 2 it gives a strike, I doesnt matter what you hit. It gives a stike no matter what. Both infa red camera detects are lit, the only way to make them unlit, is to unplug the ccd large square cable at the back of the camera, then the infa reds go back to normal operation..
    Any Ideas..
    Thanks - Ken
    Re: Scoring Problem
    IF you are using as-90's and the scorer ball detect for the scanner is always lit, it either needs to be adjusted or replaced. If you unplug it and it becomes unlit when you plug it back in, then chances are it is bad, being that it will "fall out of adjustment" soon.
    Hard work and determination is the answer to all problems.
      Re: Scoring Problem
      We have AS-90 with CCD cameras. We had a similar situation where the scorer logged in strikes all the time. One of the wires in the plug that goes into the back of the camera for power had come out. I believe it was a green wire. For whatever it is worth and good luck!
      Howard
        Re: Scoring Problem
        OK.. I left it unplugged for the night. Plugged it back in this morning, and it works. except the scoring is out on ln 2. Probably from changing the camera. Anyways. When I plug the camera calibrator in. both infa red's go solid red. and I dont get anything on the calibrator.
        Any Ideas
        Thank You
        - Ken -
          Re: Scoring Problem
          Swap the CCD processor box with the one on the next pair and see if the problem follows.
          Idiocracy
            Re: Scoring Problem
            Originally posted by Ken Moonen:
            OK.. Anyways. When I plug the camera calibrator in. both infa red's go solid red. and I dont get anything on the calibrator.
            Any Ideas
            Thank You
            - Ken -
            <font size="2" face="Verdana, Arial">Check the long plug on the the scanner tester adaptor cable where it plugs into the CCD processor box. It may be one pin off left or right, one of the end pins bent and not plugged in, or plugged in upside down. Use a light for a good look at it.
            If you can try a different scanner tester and cable, that would tell you if you have a problem with your scanner tester and cable.
            Ken Smoltz
              Re: Scoring Problem
              Scanner tester is fine. It works fine on 3+4. Gonna swap CCD Processor boxes, and I will get back to you..
                Re: Scoring Problem
                I have seen this problem, and the camera itself was bad, or bad cable connection. Especially all strikes, that is no picture...
                Rob
