Turret Index
  • Turret Index
    Ok I have a turret that wont release pins to the deck , actually it wont release pins to the deck every now and then. The 5 pin drops down, but nothing else happens. to get the rest of the pins to drop I have to cycle the turret around once, and then everything works just fine..
    Any Ideas??
    Thanks
    Ken
    Re: Turret Index
    More than likely the probe is a little too high and hanging up under the fingers, it will open up enough to allow the five pin to drop but not enough to release the spider. PJ
      Re: Turret Index
      Ken,
      check your pin bottoms from time to time. Lately, some of our pins are missing quite a bit of wood inside the bottom. It forms a hollow cup, which likes to lock down ontop of a spoon from time to time. 5 pin will drop down, relaease latch opens up, but spider stays put due to that one bad pin. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
        Re: Turret Index
        What happens if when you catch the call...instead of indexing the turret around, you reach into the 5 pin chute and push down on the pin release lever with your hand? Does the spider rotate then? The answer will help us help you...
          Re: Turret Index
          No the spider will not realse If I reach my hand in. As well as the interlock probe has pushed the blocking finger up as it should, but the spider does not release..
            Re: Turret Index
            Have you checked the spider cam follower, the small stud bearing in from of the turret? PJ
              Re: Turret Index
              Lot of good points were covered here
              fell did not release pins
              Peanut
                Re: Turret Index
                I have had this happen before, all I did was bend up the tongue in the 5 pin chute a little with a pry bar and it fixied the problem. The tongue after many years of use can become a little worn. Hope this helps.
