Pins are off spot to the right(twords 10 side),i have to move machine over,no more room to shift via deck posts,i'm off about 1/2 inch or a bit less.Can i loosen the feet and whack the legs to shift it over or do i need to do more work like loosen something else or what.
It had a broken lift shaft welded but i think it wasn't straightened good enough so i'm now off spot.Need to move it over.Looking at the legs,there seems to be enough room to shift it over and then be on spot.
Gearhead,
you can move the front half of the machine side-to-side, forward, backward, even twist it. You need to make sure your booster assembly (unless you have accelerators) is loosened up or it will hinder you from moving your machine. Loosen up the 3/4" nuts on the feet, and you're pretty much able to slide the machine around, as much as the neighboring feet will allow. If you have an old pit jogger shaft, it might help pry the machine.
Good luck. Adjusting spotting is such family fun.
Don't forget to loosen the motor mount and "J" bolts on the cross conveyor. A "come-along" is the easy way, more precise than the shove and hope method:
hey gearhead
On my A-2s I have cut 3 12"x12"x3/4" plywood and placed one under 1,7,&10 pins whith the machine at 270 resting on the plywood, if you have adjustable deck lift stabilizer's you can move the deck by adjusting the stabilizer on each side of the deck. This will rotate as well as raise and lower the front of the deck.that where the plywood comes into play. If all 3 pieces of plywood are moveable under the deck then all corners of the deck are the same and the pins should be setting correctly. only one turn at a time on either stabilizer.
hope this helps
Gaylon
I C the mechanic. I B the mechanic. I am A mechanic.
Look at your rake ?compared to the lane,and deck to see if you are able to slode frame over....if moving the frame over puts the rake hitting the side of lane,you may have to deal with your eck shaft.
Hi - I have done a lot of spotting on installation etc. Gaylon & Masternut are on the ball - you MUST make sure the front end of the machine is central to the lane before making any other spotting adjustments. If the rake board is central in both gutters you are on your way! Then you can spot the machine via the 3/4 bolts that mount the static (non moving) part of the deck, or the stabiliser arms, or slide the whole deck L - R on the deck post bearing clamps. Don't be afraid to play around & you will learn from this but make sure you get the machine central to the lane first of all. Also keep in mind your deck height & level. Good Luck. [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
