Looking for replacement upper contacts for 6525 chassis 788001057 - anyone have a source
Contacts 6525 chassis
As far as I know you can't get them new anymore. Your only chance is finding good used ones or somebody with old stock. Otherwise you have to replace the whole contactor. I've been using the 2VLH5 relay from Grainger on the 70s but they should work for 30s also. Here is the link:
https://www.grainger.com/product/SCH...ol-Relay-2VLH5
You will have to make a custom mounting bracket or I think Stahls has the mounting brackets separate (they also have the relays if you'd rather go through them. If you do, get their Robusta contactor since it's the smaller of the 2 that they sell - 070-011-755).Experience: Currently Help Maintain 44 82-30s and 50 82-70s.
- 1 like
