zot 6525 chassis
  • zot 6525 chassis
    i have three chassis that didnt survive an unusually hot day...reached 115 outside, and over 125 in the back...they all do the same thing, no matter which machine...table and sweep operate at the same time, non stop, plus no reset...cant even shut off the machine...is this a send to zot item, or do you guys fix your own? I'm going to send one in now, as I am down a machine for leagues...mine are riveted, with a foil sticker warning not to open...all input is welcomed as usual, thanks!
    Well warranty is only 90 days I think it is so after that the foil sticker doesn't matter..
    Depends what happens, if a contact comes off I'll resolder them no probs.
    Unfortunately most of our chassis aren't 12 led so they don't repair them anymore.
      yup...they told me they dont support the ones older than mine...and couldnt answer when mine would be next to discontinue servicing...i need to find a way to repair myself after, as this will shut me down...
        i have one chassis that doesnt send out the signal to shift the coil for the pin elevator...J9 on the chart...is it possible that its not sending that due to the eagle eye or other signal? perhaps this one isnt dead...
          Jon Severt repairs those chassis too.
            Is Jon Severt the zot tech, or private? I opened the chassis that only failed to send voltage to the elevator coil (J9), everything looked good...sooo...
              If I could get my hands on a wiring schematic for a chassis, I might have options...
                I'm self employed - been in business now for 33 years. I repair all of the versions of the ZOT 30 chassis, PM me if you're interested.
                Jon
