another respot cell issue
  • another respot cell issue
    One of my fellow pin chasers, who is new to the job called me and asked me how to swap out a re-spot cell. Its been several years since I have done one.
    There are three mounting screws in what I will call the outfield, because the re-spot cell is shaped like a baseball diamond. there is also a nub that I think sits down in a hole on the table. I was trying to help my fellow employee over the phone. Other than the 3 outfield screws is there anything else holding the re-spot cell in place?
    I will assume you are talking about an 82-70 type respot cell since that is what you described. This is the 82-30 forum but I will try to answer your question. You have the 3 screws as you said and then there is also a screw in the pivot pin which you sometimes need a thin 1/2" wrench to hold onto to get the screw out. And you also have to unhook the carb link that is attached to the wireway. Those are the only things holding it in there.
      Sorry about the wrong forum and thanks for the info
