So we have a 6525 mk-30 convert chassis decide to quick working on lane 16 over the weekend but it works great on lane 14. Not so good on lane 15.
When on lane 16 this chassis will not trigger. I move it to 15 and I get some power issue. The machine will cycle but the table will freeze half way down on the the re-spot IF and only IF the pin feed has not finished. If i let the pin feed finish and turn machine off then on it will continue to step 7.
I move the chassis to lane 14 and it works just fine.
I replaced the mk-30 with new rebuild and known working board.
I replaced the rectifier http://www.bowltech.com/forums/showt...ega-Tek-(info)
I replaced the T1 transformer (would like a source/part # for replacement T1 and T2, thanks)
On lane 16 I checked all the switches, replaced RPO and checked for shorts in J box. And tried to cycle machine with alligator clip J23 to ground.
What am I missing? I seems to be lack of power, what and how should I check?
