Had a good one tonight, 16 lanes running place was packed. 2 lanes were set aside for city tourney singles and doubles. The tourney bowlers were finishing up on lane 4 when it goes into continuous cycle. I am scrambling to find the problem. Checked sweep wires,ok check table wires and disconnect. still no cure. swap chassis, still cycling, I am ready to take sweep wires off and replace switch when I look and see just a portion of the top off a pin,wedged in between the backboard and side wall holding the cycle switch on the backboard, Why didn't I look for the obvious first... I would like to compile or find if someone has one a, Trouble shooters Guide to these 30's . Thanks for reading ,I know I have obtained alot of useful information here, hope someone can use this.
Always a Reason
