Possibly been discussed before
But what is the best way of cleaning (redressing) contacts on the chassis
Mainly talking Pr contacts
Also on the same note I have noticed on Two chassis that have similar faults ( drop sweep and table down on sweep) the PR2 contacts are sticking a bit
Would redressing the contacts fix this
If you sand, burnish or otherwise file the points down and see brass, replace it. Many of the contacts have just a coating of nickel or tin. The brass under it will NOT last, and will arc terribly and fail.
