looking for part # for 1/2 inch thick bumpers that hold kicker rollers back. 000-025-638 is 5/16 thick. We have some 5/16 & 1/2 & 3/4 thick loose in drawer but cannot find # for the 2 bigger sizes . Any help would be greatly appreciated. Thanks!
bumpers for rear fller plate 1/2 inch thick
Ya, I don't think AMF ever had a number for the thicker ones. You just have to find a supplier (like Stahls) that makes them. Just order the Stahls 3/4" ones and cut them to 1/2" if you need them smaller. 3/4 is usually a little too thick on the problem kickers that I try them on so cutting them a little at a time until you hit the sweet spot is usually the way to go.
LouieExperience: Currently Help Maintain 44 82-30s and 50 82-70s.
000-025-638 is the kicker bumper part number, we have always used these from AMF. If they are too thick you can always cut or grind them a little.
