quick cycles
  • quick cycles
    I was curious to know if the quick strike cycle, and the quick cycle for when bowlers pick off the 7 or the 10 pin is able to be used with the AMF 82-30 pinspotters?
    --- SteveJT66
    82/70's,kickers,Kegel Kustodian
    The only quick cycle avalible for the 82-30 is the strike cycle from Omega Tek expander, only used with the MK 30 board. 82-30 motors do not have the ability to be reversed for a quick cycle on a 7 or 10 pin pick off.
    Gene Simmons for president!!!
      Ok...good to know...I figured they were a little too old to be able to do everything the newer AMF's do.. Thanks...
      --- SteveJT66
        We have AS90 with CCD set up for A2 Bruns. on AMF 8230 with MK30 Omega Tek with out expander
        and ball trigger. I have modified our Chassis, put magnetic switches on sweep shaft at 0
        and 270 degree’s, use second output from ball trigger for 44-144 switch to read pins during
        time delay, new pin relay send signal to chassis. Modification to chassis
        disconnects table contactor when chassis try to run table this pull in a relay make chassis
        think that the table has run and felt for pins, sweep run to 270 degree switch drop out
        relays in chassis this make the chassis think it is a strike and set pins. This is a short cycle
        set up.
        This setup works on foul, 9pin and 10th frame.
        Timing is done with ball trigger.
        I have looked at a 8230 sweep motor it looks like I can cut the start winding away from the rum winding and make it run in reverse.
        I will let you now if it works.
        Dwight
        split house8-8230kicker,4-8270pbl
        surepick
        wood
        phoenix-s
        As90
        pins 2pair w/amf,2/bruns,2/linds
