82-30 4400 Chassis Help..
  • 82-30 4400 Chassis Help..
    I have one machine that appears to work fine when games are started. After the machines are running a while, it will start dropping the sweep on first ball only and scoring a gutter. Once it starts it happens pretty regularly and I Have no idea why..
    I moved the problem from lane 1 to lane 2 when I swapped the Chassis out.
    Anyone out there with any ideas, I am listening..
    What step is the stepper on? When swapping the chassis try swapping the table cams and stepper also one at a time to isolate the problem.
      Originally posted by catbowl View Post
      After the machines are running a while, it will start dropping the sweep on first ball only....
      That makes it sound like an electrical/electronic component is heating up then failing or a loose connection somewhere.
        sounds like dirty-burnt contacts {sweep} . Clean them and file the contacts.
        Later Chief
          Changed out the Cams in the Chassis and no problems tonight at all. Thanks for all the advice.. It all helps me and whoever else may view these things.
