strike cycle
  • strike cycle
    82-30 with mk-30 expander boards when hooked up on some machines sweep and table interlock-does not follow chassis
    Are both motors starting on time when they should? I've seen this happen when A sweep motor head is slow starting because starting contacts are not adjusted correctly or are burnt
      seem to be some machines do it the second i hook up the mk 30 the others just do it intermittenly--could it have anything ti do because i still have the two sa micro switches still hooked up
        I MEANT THE TWO TABLE SWITCHES
