Stepper wont step
  • Stepper wont step
    Ive a chassis on the bench that wouldn't step (no voltage at coil)
    I noticed the interrupt contacts point weren't touching (Someone had tried to bent up but failed)
    I replaced the Interrupt contact now coil hums
    Tried adjusting the top ratchet pawl arraignment but just hummed (vibrated) more??
    What am I missing
    Anyone???
      How much voltage do you have at the stepper? Might be a bad rectifier not giving the stepper enough voltage.
      Gene Simmons for president!!!
        The stepper realy coil is primarily controled by the stepper's contact bank and wiper assemblies. If they are dirty enough the relay wont pull in. You can try some contact cleaner on them see if the condition improves.
        jim8230
          I'm inclined to go with the rectifier. The coil is 90 volts dc. If you are getting a humm, could be AC voltage. But, if you jump the interruptor for a few seconds, the coil should pull in and stay in. If it does, it's in the same interruptor you changed - not a good connection when closed.
          If this is happening at 0, the home points (on top) may not be making good contact.
