plow covers
Plows are probably not your source of pin damage if they are in good knick.
Have a check for Sharp pin wheel inserts, nails in kickbacks, pin counter lever, pin cup bolts, pin deflectors, toggle fingers, protruding bolts, #1 pin track bracket to name a few......
have a look around for piles of pin chips to give you a clue. masking tape is a good test if you think they are touching something. stick a bit over suspect area and if it cuts through over time you know pins are hitting it.Duct Tape or a Sledge Hammer......such a hard choice
Originally posted by 8270king View PostNo - please do not use carpet
Use old distributor belts on the bottom where the pins impact the plows
Glue the dist belting to the plow with contact cement"Where are we going, and why are we in a hand basket?"
Originally posted by 8270king View PostCovering the contact point where the pin hits the plow with old distributor belt eliminates the plows cracking
...So does a 1 1/2" x 1/8" strap of steel welded to the back. Band-Aides come off...I prefer to do things once and done.I can't even spell Brunsw-ick anymore!!!
I would not consider a dist. belt affixed with contact cement a band aid
I would consider it preventative maintenance
I have some that have been on for 4 years -- over half of them - it is not like you spend much money or time on the installation
I agree with King. I don't consider my Plow Covers to be a band aid either. Once a plow is repaired, a cover is glued, and riveted on providing a nice pad for crashing pins; absorbing alot of shock that can crack plows. We keep our very tight and have yet to have a cracked plow in 3+ years.
12287_3811442939011_864729627_n.jpg299995_3811442378997_526592490_n.jpg"Where are we going, and why are we in a hand basket?"
I'm not saying that your way(s) are wrong or anything. I'm just going by my experience. I am in my 24th year at the same house, fighting this same problem. When I started here the cracks were coved up with duct tape. After welding them all twice only to crack again, I said screw it...Beef the bitches up and you never have to mess with it again. I just wish I would have done this the first time.I can't even spell Brunsw-ick anymore!!!
I like the idea of putting something long lasting on it to absorb the shock. In a large center the logistics of replacing all the cracked plows and or welding each and every one is impossible. Adding shock absorbing material to the plow to extend its life and also cover existing cracks is easy and in expensive and logistically compatible with a large center on a tight budget.
This makes sense.
