Random Hanging Pin with SES String Pin Setter
  • Random Hanging Pin with SES String Pin Setter
    I'm new to the bowling world, so apologies if I don't use the right technical terms.
    The center has SES String pin setters. On one machine we have a random problem.
    A pin will just hang halfway instead of being set down, or it won't be set down at all. This will happen for 2 cycles (one player turn) then it will go back to working normally. Then it will randomly happen again. Frequency rate is around 5 times an hour.
    I have tried: adjusting the string tension, checked the magnet positions, oiled the brake, checked the cam connections, checked the ohm resistance on all the spic switches. But I cannot find the problem.
    Does anyone know what I should check next? Could it be a solenoid on the CPU PCB, or do I need to replace the actual spic unit?
    Would really appreciate any suggestions. Many thanks
    I don't work with SES yet. On other machines, if a rope hangs up I check the brake. Because it occurs often, try to spend time watching that machine and catch it happen -- maybe string is catching on something as it cycles........
      Thanks for your suggestion. The string is definitely not catching on anything. The brake is engaged when the pin is hanging halfway down. To reset the pin correctly I have to manually disengage the brake. I have checked the string, there's no damage or fraying to it....
        Im only familiar with Highway 66 mini bowling lanes.
        As far as that goes, I would replace the string sensor for that pin, and see if that gets rid of it.
          Thanks for your suggestion. I think the systems are pretty similar. Do you know where the string sensor is located?
            try changing the high voltage power board, (the top board) with another lane. usually its the board that has become weak. I've had this issue many times over the last 2 years of dealing with it and pulled my hair out. Changing that top board always seems to fix the issue. I saw that you said you checked your omhs at the spic break itself. were they withing resonable parameters? should be 34-38 ohms. let me know what ya find
            If its still broken, guess it wasnt in the parts budget.
            Z
              Thanks for your reply.
              I don't have a spare high voltage power board. Do you mean just swap it with another lane? Would that transfer the problem to the other lane?
              Yes I checked the ohms at every spic brake and they all read 35 ohms.
              Do you think I need to purchase a replacement top board? Thanks
                swap the hvpbc with a known working lane to see if the issue persists. Its best to swap from odd to odd or even to even the configuration on the jumpers is a little bit different. The usual pint of failure is the power supply itself on the board. On mine it looks like a little blue box. It is always a good idea to have at least two spare hvpcb. Something that i had to learn the hard way as im in the states and the boards were coming from Turkey. Having a lane down for 5 days or more because of customs is rather annoying. let me know what you find out. Oh P.S. take a picture of the board before you disconnect anything. This will give you a referance point when you replace the board. it's the upper board not the lower. only had one lower go so far and that was on install.
                Z
                  Please get in touch direct with manufacturer > info@ses-stockach.de
                  ses-stockach.de
                  Own replacement of components mostly failed because of wrong replacement...
