Drill jig loose
  • Drill jig loose
    How do I go about tightening up a drill jig? I have an Ebonite jig with the two point hold down levers. When I tighten the set screws for the pitches the jig will still whobble as I drill into the ball.
    --Doug
    If you don't like getting beat...get better.
    Re: Drill jig loose
    If it's anything like the old Brunswick jig that I have you can clamp the upper and lower plates together with C-Clamps. That will steady it up a little.
    Another area of concern with an older machine is the arbor. It the arbor has play (check it all the way down) the bit will tend to drift in whatever direction the pitch is set to. This will throw off your spans and bridge width but it can be allowed for if you know the press is like that. It will also cause problems inside the hole on balls that have a soft core and hard weight block. Not too much can be done about that except get a new press.
    - Tony
      Re: Drill jig loose
      I was using it yesterday and I noticed exactly that...when the arbor was down it whobbled. I checked the thumb slug after and you could feel the ripples inside.
      So, you are saying that it's time for a new press?
      --Doug
        Re: Drill jig loose
        Pitboy, if your drill bits have the point off center, they will tend to wobble also. This could be due to un-profesional sharpening. This will also cause the holes to be slightly larger.
        willey.
        always doing my best.
          Re: Drill jig loose
          Doug,
          Bring the ball down to Broadway Lanes we gladly drill it for you!
          John
            Re: Drill jig loose
            Thanks John. ;-)
            They got me this press and I decided to work on one of my own balls to make sure I understood it. Now it's down back having the thumb plugged.
            --Doug
              Re: Drill jig loose
              Pit, just call Mike Corley and tell him to get off his duff and get you a decent machine!! Colchester is still using a sidewinder, and I know for a fact that I improved there high tech ball sales by about 40% while I was there. Time for them to start spening a little $$ on those who have spent a lot of $$ on them!!
                Re: Drill jig loose
                I just put in a request for a new press. Drilled a Roto last night and when I looked in the thumbhole I couldn't see the bottom it was so crooked. (well, ok, that's a slight exaggeration) But it was pretty bad. I have my eye on the second best Jayhawk for around 4 grand.
                - Tony
                  Re: Drill jig loose
                  Jack what you discribed about the drill moving in the direction of the pitch slightly is something I have witnessed a little on my drill - I no it does it so can adjust, and just have to take it real slow some times when drilling balls with a very hard core, or into a ball that has been plugged.
                  I have been thinking about getting a new press for a while, but $$$ is whats stopping that :p
                  • Bruns A-2 Man
                    Drill Presses
                    by Bruns A-2 Man
                    Can anybody tell me what kind of drill press people are using to update their older style of jigs. I have an older jig and I want to update the drill press. I believe the augor...
                    06-02-2005, 10:39 PM
                  • Duffer
                    rill press jig
                    by Duffer
                    I have an drill press that is still working great, but the jig for securing the ball has developed slight motion due to wear. I would like to find a replacement jig, but have...
                    11-14-2019, 08:02 AM
                  • sportlanes
                    Drill press
                    by sportlanes
                    I have a drill press that will not wind back up because the spring on the press is not working properley and I cannot figure out how to install the new one. any suggestions on...
                    09-05-2010, 12:19 PM
                  • HEADWEST
                    drill press help
                    by HEADWEST
                    We have an old Clausing drill press at my center that we did some ball drilling on yrs ago.It no longer has the jig so I bought a used one so I could do my personal equipment...
                    04-22-2008, 05:37 PM
                  • RipARack
                    Drill Bits vs. End Mills
                    by RipARack
                    I have just recently purchased an Innovative Mill Drill Plus and I am currently waivering on buying end-mills of just sticking with the drill bits for ovaling. I have experience...
                    11-26-2004, 01:04 AM
                  Baddest Tool Chest In Town
                  Adios, motor boater!
                  check this jam...
                  the ball stuck the table up
