thumb rolling
  • thumb rolling
    new in my pro shop and have 2 high 3/4 track bowlers, both roll over the thumb hole slightly. can i drill a hole to counter balance so no thumb roll?
    Not really, you can drill one opposite of the bow tie if they clip the fingers but on the thumb it is mostly in their release. You can change the way they come out of it by pitching the thumb and fingers different and make sure you don't drill them any pin down balls.
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
      I have a bowler at my center that for some reason he'll clip the thumb on pin up but not pin down? I don't understand it... I don't drill his stuff but is there a reason for it I'm not thinking of ???
        I would look at tilt and see if I could change the way it was released.
        Drill
        David Bolt
        Champaign, IL
        USBC Silver Coach
        IBPSIA BOD
        IBPSIA Advanced
        Technical Certified
        Pro Shops
          I'm a high track player (5 1/4" > X 1" ^) and whenever I drill pin under I have to remove finger weight to keep from clipping the thumb and/or middle finger hole. Are the bowlers in question using a pin under drilling?
          GSX Noob
