Self Contained Resettable Pin Release
  • Self Contained Resettable Pin Release
    I finished this prototype couple weeks ago and finally got a rough video created. I solved all of my 3d printer issues. I got the glass bed working. It turns out that the glue stick system works great. This video shows various views of the 1/2 scale device. I created all of the parts for a 1/3 scale version but I need to get pictures of all of the parts, label them and them create a series of assembly photos and videos. In any event, the 1/2 scale device is here:
    That is a truly innovative design you came up with there. I could never quite tell what was happening in your previous videos but I can clearly see the operation now.
      Thanks Coaster. When I get time I want to make a full set of 1/3 scale units, mount them on a table and put it into operation on my 1/3 scale lane. Yes, the original prototype and videos left a lot to be desired.
        Very nice! Like coasterp said, very innovative!
        Mike Wilson
        Bowl-Tech Inc..
