Over 3,375 games on mini lane
  • Over 3,375 games on mini lane
    Well gang, I have over 3,375 games on the mini lane so far since May 2010!! This does not count the open frames bowled without keeping score! Everything is holding up great!! My friends love this lane..... Is anyone else keeping track of the amount of games on their mini lanes?
    --- SteveJT66
    82/70's,kickers,Kegel Kustodian
    That is simply amazing Steve, and a testament to your construction that it holds up so well over that many games. What do you use to keep track of the games? Do you have some sort of database that tracks scores, averages, etc. per bowler in your basement?
      Hi Jeff,
      No, don't have any computer programs or anything, I just keep all the score sheets, and then keep a running total at the top of each one. I have a binder with all the bowler's score records, dates, averages, games bowled, hi game...etc...
      --- SteveJT66
        This would be Steve the statustition!
        70's MP/PBL/LBS,Q-Score
        Prolane Walker sport
          That is a lot of bowling. ANy breakdowns??
            Just think if you were charging $2.00 a game you would have made $6750. Thats a lot of manual pin setting. You still using the same set of pins?
              Yep...I guess that's me......LOL
              --- SteveJT66
                the only thing I guess, would be a few of the tubes that hold the pins in the setter came loose, but I have since permanently fixed that problem. I have wooden support collars epoxied around them, so they should never come loose again!
                --- SteveJT66
                  I am rotating between sets, I am on the second set of 20 pins, then I will put back the first set of 20 pins in the summer time.
                  --- SteveJT66
                    With the two sets of pins I just put in at the end of August 2011, I have a pin where the base ring came off. The first two sets I had in that I removed to rotate the newer ones in, were in over a year, and no problem. Is that due to maybe a defect in manufacturing of that particular pin?? It's been in use just under six months. Probably has about 1,200 games on them. I read that Linds has a lifetime warranty on the base rings. has anyone had a problem with the base rings at all?
                    --- SteveJT66
                      No problems here. Probably just a fluke.
                        No problems with the base rings here. My issue has been inconsistency with the size of the width of the pins. I have 2 or 3 that are fatter than the others and they want to stick in my setting cups.
                        www.BasementBowling.com
                          UPDATE: Now officially over 4,000 games as of last night, the grand total of games bowled is 4,028 !!!!! Not counting open frames of course without keeping score...these are the games scored.
                          --- SteveJT66
                            Awesome job, Steve! This really speaks volumes about the unit's construction. I think it looks great myself.
                              Thanks Compy.....still lookin' new..!!
                              --- SteveJT66
                              Blue A2 Rebuild
                              Here are photos of the A2 that I just finished rebuilding and installing. Every single part on the machine came apart to be cleaned, painted, or replaced. All new rubber,...
                              Streamlane Mask Halo Lights
                              Hybrid (and EcoFriendly) Bumpers (2012)
                              It's been about 10 years since we first tried this - 46 lanes and still working fine, auto air bumper cylinders on the BankShot bumpers. Here are videos of a home install with...
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
