I've been lurking here for a while and some of you may have already heard from me between here and youtube. I am in the process of developing the pindeck/pit section. I have 21 feet of space, so the lane will be shorter in that sense, but I am designing it in sections so the length can be increased when it is moved. (My next home will have an unfinished basement with hopefully 30 feet when the time comes).
Scoring: I am a software engineer by day, so I decided to write my own application for scoring that uses a standard webcam with some image manipulation so I can count the white "blobs" on the pindeck to determine the pins left standing on the deck. Obviously this will require some tolerance to account for off-spots. Currently this project is going well and I hope to have a video up soon. Note that if I get this working reliably, I will release any source code on github so you guys can set up a scoring system for your lane based on commodity hardware!
Lane Hardware/Surface: None of the centers in the area have resurfaced recently/do not have any lane surface left over so I will most likely be using laminate flooring as I've seen it work pretty well on several of you guys' projects.
The bedding I am thinking of placing on 2x12s. If any of you have building suggestions on making it sectioned or just lots of pictures from your building process that turned out well, I encourage replies to this thread! I am all for avoiding reinventing the wheel.
Pinspotters? Eventually: I like the ability to run the deck sweep off of one motor in all positions... theultimateandy has been beyond helpful with this and I will be replicating his AMF 8270 sweep design, I love it and its quite elegant (as a kid, I never knew why they had so many joints in one arm assembly, when brunswick seemed to be doing it simpler at the time... or so I thought). Now I *do* like the turret assembly on the top of the deck as seen on A-2's, so I am using the small scale A-2 video as well as my past experience with these units to pick apart the details.
Control: The control will be done by a computer. I took several robotics courses in my undergrad, so I may be able to apply some of the knowledge here. An arduino will be the direct hardware interface to the system. It will drive several servos and relays to higher power motors that perform the machine's critical functions. I imagine motors will be required for pindeck elevation, pindeck grab/release (scissor deck), turret rotation, turret release (I could make this mechanical), pinwheel operation and sweep assembly. I have been paying close attention to the QBowling pinsetters. Very cool things, they are!
Anywho, thankfully I know a carpenter who happens to also be a bowler, but if you guys have any media/pics/videos on the development of your lane (or even documentation), please feel free to post it here! Otherwise you could see some new fresh and wonky designs.
Question: For those of you with the Linds mini pins, have any of you experimented with clear coating the pins? This could be a dumb question, but I am curious as I've seen videos where the paint seems to flake off over time... its a shame they cost about $90 shipped now. Mine just came in and are at the house unopened, so hopefully they'll last a bit longer.
Major thanks to Steve, Andy, Dave and everyone else who has posted media on your half scale lanes, its been quite helpful!
More updates as progress continues.
Jimmy
