Ball damage help.
  • Ball damage help.
    No stop on lane. Just found out at the end of the night. What might cause this.
    You may only view thumbnails in this gallery. This gallery has 1 photos.
    Looks like damage is from it spinning somewhere and hitting something. I'd check ball return up front. Bring a flashlight and look for ball shavings.
      I did not see anything but our proshop said he cleaned it off with acetone. The ball wasn't actually damaged. Ball return has good c tracks and v wheels
        Was it idling on the carpet? Rubbing on something - cushion rivets etc. Or partway into the ball exit and rubbing against PBL lift belt.
